[SOLVED] Problems pushing values from a Photon device to Blynk
Hi!.
i’m new to Blynk and on my first code, i just try to push a value from my Particle Photon to Blynk via Virtiual Pin V5. The code is the following:
#include "blynk/blynk.h"
char auth[] = "ELIMINATED"; // Put your token here
Timer mytimer(5000, sendUptime);
  delay(5000);
  Serial.println("Start");
  Blynk.begin(auth);
  mytimer.start();
void sendUptime()
  Serial.println(millis() / 1000);
  Blynk.run(); // all the Blynk magic happens here
However, when i run this code, no values are printed on the terminal, nor sent to blynk, and after a while, the status led on the device lights red, and it initilizes. In case i comment the line Blynk.virtualWrite(V5, millis() / 1000);, at least the values are printed on the terminal and it works fine … where is the problem with this code? Any help will be appreciated. Thanks
@fbt think you are missing the timer in loop().
Hi @Costas … as reported, in case i comment the line Blynk.virtualWrite(V5, millis() / 1000); it works ok ans the following values appear on the terminal, so i don’t think the problem is related to that.
Opening serial monitor for com port: "COM13"
Start
23
28
33
38
43
On photon, you need to use SparlCorePolledTimer
Thanks @vshymanskyy … now it works ok.
