[SOLVED] No connection to server blynk
Hello!
I can not connect to the server . Have tested various hardwares and I’m setting everything right ! Nothing happens! Please I need help!
Hello. Please use english and provide more info. What hardware, what connection type, what does serial output shows, etc. Good start would be http://docs.blynk.cc/#getting-started
Hello! Sorry!
I can not access the original Arduino Uno board with w5100. Already tested the App before with ESP cards, and worked perfectly. I’m following all the steps but the board does not connect in Blynk server. I’m doing everything correctly, but the App not think my card on the server.
Problem solved!
I used manual configuration and connected !
Thank you all
