[SOLVED] New iOS Level widget problem
Hi.
I’m trying to use the new level widget and I can’t add a label to it. All I get is the pin value listed on top of it. Also, when I edit the widget, there is nothing on the top part.
It would be nice to be able to change the color of the widget according to the value, like with the Gauge, as well as enter a label /pin/ºC, for instance, to show the temp or whatever.
Hello. Agree this would be great improvements. For now this is not implemented. You can change color via setProperty.
I was assuming the color was fixed but I can see now that I can change it with the setProperty. Thank you. By the way, you guys rock. This is by far the most exciting app to make IOT a practical thing. I have a Homeseeer home automation system and I’m quickly switching the HS GUI to Blynk. Very neat and very easy to implement.
Luis
Thanks!
