I just installed the new Android version of Blynk (1.13.0, 10/7/16), but it crashes each time I click on the Bluetooth BLE widget (in the design mode, so before really running the project).
I am using Android version 5.1.1 on a Samsung galaxy sm-g800f.
Strange because this worked in the previous version of the Blynk-app.
I tried to reinstall the app, but the problem remains.
Thank you for reporting. We will try to make a fix ASAP.
@federicobusero pls check latest version.
Version 1.31.1 (11/7/2016) still crashes when clicking on BLE widget of an existing project, but now there is a workaround: simply delete the project in the app and create a new project.
So it seems there are some non-compatible features in this app, which is ok because BLE was in Beta-phase. Thanks for the quick response!
Federico
My analysis was wrong: the BLE widget bug is still there. So once the BLE widget is connected to a HM-10 module, the app will crash when you hit the widget (in design mode). The workaround is … not to touch it. In case you want to connect to another BLE module, then the workaround is to delete the project.
Thank you again for reporting. Trying to reproduce.
please check with latest update, we have updated app yesterday once more - so the should be no problem with opening ble widget’s settings with connected ble device.
I confirm that it solved in version 1.13.2
