I’m doing this project from a homemade egg-hatcher. But I’m having a problem, it works perfectly, but after 10 seconds it disconnects from the internet there I get without receiving the data, although it keeps working…
Could someone tell me why she’s disconnecting from the network? After ±10s.
I’m using:
MKR 1000 arduino
IPhone 11
My Code:
/Incubadora de ovos
#include <Wire.h>
#include <EduIntro.h>
#include <WiFi101.h>
#include <BlynkSimpleMKR1000.h>
#include <DHT.h>
#define pRELE 7 //(relé con calefactor conectado al pin 7)
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
char auth[] = " ";
int vcc= 11; //crear pines de 5v // acrescentei
char ssid[] = " ";
char pass[] = " ";
void TimerEvent()
int h = dht.readHumidity();
int t = dht.readTemperature();
int C;
C = dht.readTemperature(); //acrescentei
Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V5, t);
Serial.println(C); //acrescentei
ServoMotor servo(D6); // creating the object 'servo' on pin D10
pinMode(pRELE,OUTPUT);
pinMode(vcc,OUTPUT);
//Blynk.begin(auth, ssid, pass);
// Or specify server using one of those commands:
Blynk.begin(auth, ssid, pass, "46.101.143.225", 80);
timer.setInterval(2000L, TimerEvent);
dht.begin();
digitalWrite(vcc,HIGH);
//DHT.read t(dht_apin); // Read apin on DHT11 or DHT22
if(dht.readTemperature()<37)
digitalWrite(pRELE,LOW);
delay(2000);
digitalWrite(pRELE,HIGH); // digitalWrite (pVENTILADOR,HIGH);
servo.write(135);
delay (7200000); // wait for two horas
servo.write(50);
delay (7200000); // wait for a second
Pete
Thank you very much, it was perfect now… Just one little thing missing, the temperature is taking about 13 seconds to update and that’s a lot, because it will elevate the temperature of the hatch a lot. You could guide me as I shorten the time for DHT to read the temperature…
Thank you.
here goes the code as it did after his guidance.
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
#include <Wire.h>
#include <DHT.h>
char auth[] = "";
char ssid[] = "NosAky";
char pass[] = "";
void TimerEvent()
int C;
dht.begin();
void Iftemperature()
void loop0()
servo.write(135);
delay (6000); // wait for two horas
servo.write(50);
delay (6000); // wait for a second
loop0();
Iftemperature();
You can’t just move the offending items out of your void loop and into their own functions, then call them on every execution of the void loop!
You should take a temperature reading, then (in the same function) check whether the temperature is within your desired range and take the appropriate actions.
Your information helped me solve the problem.
Thanks again.
