[Solved] iOS Menu widget sending wrong values
I am working on a project for a friend with an iOS device and noticed that when selecting an item with the menu widget it will send the wrong value to the server. It seems to be treating the menu widget like an array and sending 0 for item 1, 1 for item 2, etc…
I cloned the app to my Android phone and it works perfectly so this seems to be directly related to the iOS version of the Blynk app. According to https://github.com/blynkkk/blynk-library/issues/107 the starting value should be 1 which again, is working as intended with the Android app.
I have a work around for now by adding 1 to the number received but figured I’d let you know.
Hello. Thank you for reporting. We will check.
Fixed. Will be released in next update.
Great! Thank you for getting it taken care of so fast.
