Hello, I Use NodeMCU ESP8266 try to make project with Arduino IDE.I want make ESP8266 indicator connected to server by using LED as indicator.
How to code Arduino IDE make ESP8266 indicator connected to server by using LED as indicator,
if connected LED is on,
otherwise LED is blinking.
@Aldwin Also check out all the Help Center documents (links also at the top right of this page)… they are there to help you learn how to use Blynk… e.g.
Hello, @Gunner i’ve learned, but i want to make is how to make indicator in ESP8266 (built_led / d4) can be an indicator if it is connected with blynk server. So when connected blynk server (builtin_led / d4) = low, and when not connected blynk server (biltin_led / d4) blinks 1sec. If i made it on serial monitor for connected indicator already i can, i add digitalwrite (led, low) led not on. Please help me
@Aldwin study PUSH_DATA example to achieve your 1s intervals. Then if you are still struggling post your bad sketch. Also read “Connection Management” posts in the docs and on this site (by most recent post).
Well, I think what you are looking for will require some of the Connection Management commands… particularly the boolean logic of the Blynk.connected() command.
Perhaps something like this (untested as I am still learning these connection management commands myself ;))…
if (Blynk.connected()) { // to ensure that Blynk.run() function is only called if we are still connected to the server
// flash disconnected led routine
This is my sketch with Wemos.
if connected LED is fade in fade out
if not connected LED stop fading.
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- ESP8266 board
example.
const byte pwmLED = LED_BUILTIN;
// define directions for LED fade
#define UP 0
#define DOWN 1
// constants for min and max PWM
const int minPWM = 0;
const int maxPWM = 1024;
// State Variable for Fade Direction
byte fadeDirection = UP;
// Global Fade Value
// but be bigger than byte and signed, for rollover
int fadeValue = 0;
// How smooth to fade?
byte fadeIncrement = 5;
// millis() timing Variable, just for fading
unsigned long previousFadeMillis;
// How fast to increment?
int fadeInterval = 10;
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
analogWrite(pwmLED, fadeValue);
void doTheFade(unsigned long thisMillis) {
// is it time to update yet?
// if not, nothing happens
if (thisMillis - previousFadeMillis >= fadeInterval) {
// yup, it's time!
if (fadeDirection == UP) {
fadeValue = fadeValue + fadeIncrement;
if (fadeValue >= maxPWM) {
// At max, limit and change direction
fadeValue = maxPWM;
fadeDirection = DOWN;
//if we aren't going up, we're going down
fadeValue = fadeValue - fadeIncrement;
if (fadeValue <= minPWM) {
// At min, limit and change direction
fadeValue = minPWM;
fadeDirection = UP;
// Only need to update when it changes
// reset millis for the next iteration (fade timer only)
previousFadeMillis = thisMillis;
// to avoid delay() function!
unsigned long currentMillis = millis();
doTheFade(currentMillis);
