[SOLVED] History graphs only reads "Loading...". Server issue?
It worked well yeasterday and days before. Is it a server issue?
All others widgets I use works well.
Hello. Please provide more details. Is that iOS/Android? Maybe some steps to reproduce?
Android. Noticed the problem this morning when I powered up my Galaxy Note 2. It worked well yesterday. Another Blynk application (on same mobile) has been running with history graph for months until today. I downloaded the new Blynk app today, but the problem remains.
I didn’t do anything more than just powered up my phone this morning.
Please try logout and login again. Does that help?
Can’t figure out how to log out. But restarting app did not help.
Button at top-left corner.
I noticed the same problem with graphs this morning. Log out & log in did not change a thing.
All other widgets still work.
Looking into it. Thank you for reporting.
I noticed already yesterday (10 sept ) that graphs loading was slowed down… Now I only get the "loading… " message .
@Magnus @Energyduino are you using Androids? Latest app version?
I run the application on IOS ( ipod) and Android ( One+ phone). Both graphs stay in the status loading…
My Blynk installed version and application, was OK till now. It runs since (exactly ?) 3 months without problems (= max time scale of the graph. Possibly this is a time - limit , explaining my recent graph-loading-problem ? )
@Magnus @Energyduino should be fixed right now. Please check.
just perfect now !!!
Excellent. Thanks!
Thanks again. (min. 20 chars)
Hi guys,
I’m facing this issue as well since 2 days ago. Running on Android connected to the Blynk cloud with the latest app version. Tested on an xperia as well as a nexus 7. Both showing the graph with “loading…” text but never loads.
Same here it’s been 3 days today no graph only loading text is all we can see instead …
Thank you for reporting. We’ll check.
I am also facing this infinite history graph loading … issues since yesterday.
I am using Blynk app version 1.15.3 on android v 6.01.
I am also having the same issue, also all buttons stoped working, thought might be because of iOS 10
@JulianT @alahsan @rajeshcvani @haidar23 does someone from you uses bluetooth widget?
