[Solved] Help with test bridge project
Hi all,
I would appreciate any help.
I am trying to make 2 nodemcu talk via bridge widget…
Sender code:
#include "SimpleTimer.h"
#include <WidgetRTC.h>
const char* auth     = "........800d74a42";
const char* ssid     = "AnxxxDSL";
const char* password = "xxxx";
SimpleTimer     MyTimer;
int             MyId;
WidgetBridge bridge(V0);
BLYNK_CONNECTED()
  bridge.setAuthToken(".......66a45f");
void MyProc()
  unsigned long time;
  time = millis();
  Blynk.virtualWrite(V1, time);
  Serial.print("Sending: ");
  Serial.println(time);
  Serial.begin(256000);
  Serial.println();
  Serial.println();
  MyId = MyTimer.setInterval(5000L, MyProc);
  Blynk.begin(auth, ssid, password);
  while (Blynk.connect() == false) {}
  Serial.println("Connected");
  MyTimer.run();
Reciever code:
const char* auth     = "........66a45f";
const char* ssid     = "xxxxxSL";
const char* password = "xxxxx";
bool        isFirstConnect = true;
BLYNK_CONNECTED()
  if (isFirstConnect)
    Blynk.syncAll();
    isFirstConnect = false;
BLYNK_WRITE(V1)
  int value = param.asInt();
  Serial.println("Got Value:");
  Serial.println(String(value, 1));
  Serial.println();
  Serial.println();
  Serial.println("Starting");
Thank you
ok, and what is the question / problem?
what is happening and what do you expect to happen?
I cant get the “receiver” to get value from the sender…
are these prints appear every 5 second in sender serial monitor?
As far as I can see, you are not actually sending any info over your bridge… you need something like this:
bridge.virtualWrite(vPin, value);
nah, nice catch!
it means time to go to sleep for me :wink:
Thank you:slight_smile:
Will try that…
Thank you guys.
That was it.
For future Reference:
Sender:
const char* auth     = "......00d74a42";
const char* ssid     = "xxx";
const char* password = "xxx";
int             MyId;
BLYNK_CONNECTED()
  bridge.setAuthToken("......dd66a45f");
void MyProc()
  unsigned long time;
  time = millis();
  bridge.virtualWrite(V1, time);    //  <<<<<<<<<<<<<< Here was my Mistake!!!
  Serial.println();
  Serial.println();
  MyTimer.run();
