[Solved] Help with LED in BLYNK App
Hello, how do I Blink LED Widget show the status of a pin on the Arduino Uno? High level or Low level?
Have you bothered to try any of the Blynk examples and if so what results did you get?
I tried, but I could not, the Widget LED LED 3 (V 3); can directly read the value of the pin? Or should first assign the value of the pin to a variable?
Paste in your formatted sketch and ensure it has plenty of comments so we can understand it.
The pins are virtual so I’m not really sure what you mean about directly read the value of the pin.
Friend, as I did, I was trying here and put the value of the pin state in a Boolean variable and it worked!
define BLYNK_PRINT Serial
include SPI.h
include Ethernet.h
include BlynkSimpleEthernet.h
char auth[] = ā€œā€¦ā€;
WidgetLED led3(V3);
boolean estadoBotao;
Blynk.begin(auth);
pinMode(7, INPUT_PULLUP);
delay(500);
estadoBotao = digitalRead(7);
if (estadoBotao == HIGH){led3.on();}
else{led3.off();}
Glad you got it sorted but ensure sketches are formatted with the </> button as the one you posted leaves us guessing which libraries you are using.
