I use Blynk to monitor a water level sensor among other things; I checked my app a couple of days ago and all it says is “Create new project”. I logged out and back in, but to no avail.
Surprisingly the API for this is still returning PIN data, so I think it’s just an issue with the app.
I’ve just had something similar with Android app. My project has disappeared. It happened a few months ago too, and that time I ended up re-creating my project from scratch… which was very annoying.
So when it just happened again, I came on to forums to find a different solution this time, as I really don’t want to re-create my project a third time.
Will try deleting app, and see if my project comes back too, but before I do that, I thought I’d post in case you wanted any troubleshooting info before I nuked the app…
This is probably it; I’m out of country at the moment and it must be using another server. If we’re using geodns, one would expect the servers to be in sync
@Gopi_Aravind send a PM to @Dmitriy with your email details and he will find out which server your account is on and provide you with an IP address for your app.
Blynk have a fix for geo-dns but it requires Blynkers to be using the latest libraries and until more of them switch it will break the system for more people than it will help.
