Hello everyone, first I apologize for my bad english. I use the Arduino UNO and Esp8266 module. ESP8266 has current software. I didn’t provide a healthy internet connection although I did the connections and encoding correctly.
It’s clearly not a Blynk issue, although some Blynkers may be interested in the eventual solution.
Maybe try re-flashing with the latest AT firmware, or searching on ESP forums, or buying a NodeMCU and using that instead of both your Arduino and ESP-01.
AT
OK
AT+GMR
AT version:1.2.0.0(Jul 1 2016 20:04:45)
SDK version:1.5.4.1(39cb9a32)
Ai-Thinker Technology Co., Ltd.
Integrated AiCloud 2.0 v0.0.0.3
Build:1.5.4.1 Jan 10 2017 18:32:04
OK
I think you need to Google for some other firmware and flashing method, then try again.
As a shield, I simply ran with whatever AT firmware it had preinstalled when I purchased it. I did mess around long ago with reflashing the AT firmware back on one, after test flashing Arduino code on it, but you can Google for the hundreds of tutorials on how to do that.
I think firstly, you should make baudrate together in same value
Your code in define : #define ESP8266_BAUD 115200
But in setup:
Dear…
In example code of arduino, have ex about read humdity and temperature use DHT11
If you got trouble, you can reference. It better for your project
Arduino + Esp 01 very good in small project
Basically, arduino can work with so many sensor type (use 5VDC) instead 3.3vdC
Everyone can easy work on it
And i think with any project have so many interesting things for us to explore
