BLYNK
<solved>Guidance on CSV output history data specific pin
Hello all
Wanted to know I was able to view the corresponding history data of specific pin in local setup using API as it was for temperature sensor it did showed me the past temperature readings but there was no timestamp or may be another column has same as it’s only representing numbers like(1565493960000) kindly guide me , also please guide me how old the data are there any certain period?..Thanks
You should really be using the Reports widget to extract the data, as I believe the method you are using may be dropped in future. However, to answer this question…
Those numbers are the date and time in UNIX format (the number of elapsed seconds since 01/01/1970). It’s simple to convert them to normal time format in Excel.
Thanks a lot
