I am newbie at Blynk and I am using particle Photon, and also newbie with this board.
I do not use the Arduino neither Arduino IDE.
I am trying to figure out how to visualize data form the “Get Data sketch” with no serial terminal like the one included in Arduino IDE.
Gunner one more question.
What firmware function should I use for send data to the TX pin of Particle Photon?. That data is gonna be created for a slider widget o Blynk app which is gonna send data to a virtual pin V1.
Thank you for your help.
Thank you, done!, you helped me to put the bullet on the right target.
I used :
BLYNK_WRITE(V1)
Blynk.virtualWrite(V1, pinValue) ;
Blynk.virtualWrite(V2,pinValue);
Yes, you are Right !!!.
If you don’t mind I have other question/commentary :
Just for curiosity and tinkering with Blynk I added one second slider to the original one to change bright on a led.
I saw with surprise that for Particle Photon , with 8 DO, just 1 slider get 2 DO .
I added one more slider and only left 4 DO with PWM.
What if I need more slider for a Lighting Control in this case with Photon, should I use Virtual pins ?
[3] PWM is available on D0, D1, D2, D3, A4, A5, WKP, RX, TX with a caveat: PWM timer peripheral is duplicated on two pins (A5/D2) and (A4/D3) for 7 total independent PWM outputs. For example: PWM may be used on A5 while D2 is used as a GPIO, or D2 as a PWM while A5 is used as an analog input. However A5 and D2 cannot be used as independently controlled PWM outputs at the same time.
So 7 simultaneous PWM pins is your physical limit, regardless of how you access them; Directly via the Digital Pin setting in the App, or via Virtual Pins on the App with analogWrite() in the coding.
Virtual pins however will give you more flexibility… say you want to control the simultaneous dimming of multiple LED lights with just one slider…
BLYNK_WRITE(V1)
analogWrite(D0, pinValue);
analogWrite(D1, pinValue);
analogWrite(D2, pinValue);
