(SOLVED) Gauge Widget: Displays junk values when combined with text or symbols
OK @BlynkAndroidDev Right off the bat I can confirm that there is an issue with the Gauge’s /pin/ variable received either as Integer or String, and from any source (tested with sketch supplied, slider and terminal).
It functions normally, until the first matching number, then it seems to truncate any preceding label text, displays the matched number along side the /pin/, then carries on as normal. What fun :smiley:
And at risk of turning this topic into Pinterest :wink: here is more picture examples when /pin/ is processed as 0-5 with the numbers 1234 in the label.
