Hi. I need help my door opener project keeps resetting. Hereβs the code
SimpleTimer timer_door_contact;
//SimpleTimer Force_WiFi_Timer;
void Post_WiFi_Signal(){
String Force_WiFi;
String All_Infos;
All_Infos = getCurrentDate() + String(" ") + getCurrentTime() + String(" Wifi: ") + map(WiFi.RSSI(), -105, -40, 0, 100) + String('%');
RSSI_LCD.print(0,0, All_Infos);
#define ssid "VIDEOTRON2944"
#define pass "K7E97YHEA9JAM"
// garage MARC
char auth[] = "0d23539d01984293a0675b7041d027e6";
// garage MAMAN
char bridge_auth[] = "a414457c01284b78a505981409724e96";
// IFTTT setup
const char *host = "maker.ifttt.com";
const char *Maker_Event = "Your EVENT Name";
const char *Your_Key = "Your key on Maker Channel";
#define GARAGE_LOCK D1
#define DOOR_SENSOR D7
#define LED_GARAGE_OPEN D5
#define LED_GARAGE_CLOSE D6
WidgetBridge bridge1(V1);
WidgetLCD lcd(V3);
* PORTE DE GARAGE FERMΓE = 1
* PORTE DE GARAGE OUVERTE = 0
void check_door_contact(){
lcd.clear();
lcd.print(0, 0, "PORTE DE GARAGE "); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
int valueDoorContact = digitalRead(DOOR_SENSOR);
if (valueDoorContact == HIGH){
lcd.print(5, 1, "FERMEE");
bridge1.virtualWrite(V6, 0);
digitalWrite(LED_GARAGE_OPEN, LOW);
digitalWrite(LED_GARAGE_CLOSE, HIGH);
if (valueDoorContact == LOW){
bridge1.virtualWrite(V6, 1);
lcd.print(5,1, "OUVERTE");
digitalWrite(LED_GARAGE_OPEN, HIGH);
digitalWrite(LED_GARAGE_CLOSE, LOW);
} // void check_door_contact()
void Ecrit_Force_WiFi(){
String Force_WiFi;
Force_WiFi = map(WiFi.RSSI(), -105, -40, 0, 100) + String('%');
Blynk.virtualWrite(V5, String(Force_WiFi));
// setup
void setup(){
pinMode(GARAGE_LOCK, OUTPUT);
digitalWrite(GARAGE_LOCK, LOW);
pinMode(DOOR_SENSOR, INPUT);
pinMode(LED_GARAGE_OPEN, OUTPUT);
pinMode(LED_GARAGE_CLOSE, OUTPUT);
timer_door_contact.setInterval(10000L, check_door_contact);
//Force_WiFi_Timer.setInterval(5000L, Ecrit_Force_WiFi);
while (Blynk.connect() == false){
// Wait until connected...
lcd.clear();
// loop
void loop(){
timer_door_contact.run();
//Force_WiFi_Timer.run();
bool firstConnect = true;
BLYNK_CONNECTED(){
bridge1.setAuthToken(bridge_auth);
if (firstConnect) // When we first connect to Blynk
Serial.println("First Blynk connected...");
Blynk.notify("Garage Door Opener MPE Started!");
lcd.clear();
Blynk.syncAll();
firstConnect = false;
// This function will be called every time
// when App writes value to Virtual Pin 0
BLYNK_WRITE(V0)
BLYNK_LOG("Got a value: %s", param.asStr());
int myValue = param.asInt();
if (myValue == 1){
digitalWrite(GARAGE_LOCK, HIGH);
bridge1.virtualWrite(V0, myValue);
