[Solved] Eventor, cannot add event!
Hi all, thank’s for theservices that’s really great !:smiley:
I was able to create some eventor senario in my app and lynked to widget.
But now for some reason, I try making a new one and in the process of creation, afther selecting variable, condition, then! No event show up to complete the Eventor… ?
Is it me or a bug? (Android)
Edit: it work on my other Android device… ?? At least I could add what I was looking for.
Thank’s
Hello. Did you fully filled event? Did you click “OK” at the end? Video would help us a lot.
Thank :smiley:
I can’t finish the command !
I select the input, the operator, then I enter the value but I’m stuck there, I click on my check icon on my screen nothing append.
@Buz4x4 are you saying you can’t press the “OK” positioned top right of the app?
Yes and no lol
I cannot complete, after I enter the 50 value…
I should press the check mark and pass to next action… but nothing append.
If I click Done I lose what I just enter.
@Buz4x4 Ok so you are using Android, what version and what phone?
What Blynk library version are you using?
Are you connecting to the Blynk cloud server or to a local server?
Once I have your answers I’ll try and test from here. As a coder we don’t use Eventor very often but it’s a powerful tool for those that need it.
Android 4.4.4
Nexus 5
Blynk cloud server
Blynk lib. 2.12.5
Thank you :smiley:
…SH!t !!!
I’m so sorry !
I juste made a test I should have done before.
The problem is from my keyboard, it’s not the Android default…
My problem is there, it won’t show the Done button… Compare the image below vs the previous post.
Shame on me, I’m very sorry.
Thank you a lot.
At least someone esle could benefit from that.
Lol. @BlynkAndroidDev FYI
Seems we need to update UI for such keyboard cases.
Won’t be needed, I updated “AnySoftKeyboard” it’s working now.
Thank you very much for your help!
I’m going to give a 5 stars review right now on play store…
You deserve it!
Great app plus fast support! :+1::ok_hand:
