Hi. I need show clock in blynk. But this sketch show bad value… ?
THanks…
#include <DHT.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Wire.h>
#define DHTPIN 12 //pin gpio 12 in sensor
#define DHTTYPE DHT22 // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = ""; // Put your Auth Token here. (see Step 3 above)
WidgetRTC rtc;
Blynk.begin(auth, "", ""); //insert here your SSID and password
timer.setInterval(10000L, sendUptime);
timer.setInterval(10000L, clockDisplay);
Wire.begin(4,5); //ds3231: 4-D2 SDA. 5-D1 SCL
rtc.begin();
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
void sendUptime()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
Blynk.virtualWrite(12, t); // virtual pin
Blynk.virtualWrite(13, h); // virtual pin
