(SOLVED)ESP8266 resets when using Blynk.virtualWrite inside the interrupt routine
Hello All,
I am using a push button thru interrupt in ports D6 and D7 in nodemcu, I put a capacitor and debounce routine also. All is working fine as expected, but when I insert a line with Blynk.virtualWrite to send a status to Blynk, the ESP reset at this stage. I tested with differents nodemcu and seems the same.
here is a part of the code involved in this:
 pinMode(D6,INPUT_PULLUP);
 attachInterrupt(digitalPinToInterrupt(D6), onChange1, FALLING);
void onChange1() {
    boolean debounce1 = false; //ignora leitura falsa
   //se tiver trigger rapido e falso dentro do limite, vai ignorar
  if((millis() - lastDebounceTime1) <= debounceDelay1) {
    debounce1 = true;
  lastDebounceTime1 = millis();
  if(debounce1) return;
     if (led1 == 0) {
        digitalWrite(D3, HIGH);
        led1 = 1;
        Serial.println("LED-1 off");
        Blynk.virtualWrite(V7, HIGH); <===== here is the issue when I insert the virtualWrite.
        return;
      if (led1 == 1) {
        digitalWrite(D3, LOW);
        led1 = 0;
        Serial.println("LED-1 on");
     // Blynk.virtualWrite(V7, LOW); <==== the same
        return;
Have anyone seen this behavior?
Werner
Are you sure you need the debounce routine in the software with a capacitor in place? I’d remove it. A cap should be enough from my experience (hardware debounce trumps software if you ask me) :slight_smile:
Yes interrupts are very messy with ESP’s, even SerialPrint() can crash the device. There are 2 solutions, detach the interrupt as soon as it has been called and then reattach when the function completes. Plus try setting a flag from the interrupt and no more. Then with a timer, check for the flag and do the Serial.print() and virtualWrite().
Guys, I just removed all of my libs, then installed the Arduino IDE 1.8.4 (I was in 1.8.3), installed blynk lib and all worked.
Also I will implement “detach/reattach”.
Thanks for the help.
Werner
