[SOLVED] ERROR When Flashing Arduino MKR1000
Hi all i’m having this error when i try to flash my sketch in my MKR1000 using the sketch example from Blynk
C:\Users\COFFEY\Documents\Arduino\sketch_jun11a\sketch_jun11a.ino:32:21: fatal error: WiFi101.h: No such file or directory
 #include <WiFi101.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino MKR1000.
This is the sketch
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Blynk using a LED widget on your phone!
  App project setup:
    LED widget on V1
#define BLYNK_PRINT SerialUSB
#include <BlynkSimpleWiFiShield101.h>
char pass[] = "YourPassword";
WidgetLED led1(V1);
// V1 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
    led1.off();
    SerialUSB.println("LED on V1: off");
    led1.on();
    SerialUSB.println("LED on V1: on");
  SerialUSB.begin(9600);
All the libraries are installed in the following path:
C:\Users\COFFEY\Documents\Arduino\libraries
C:\Users\COFFEY\Documents\Arduino\tools
Don’t understand why this is hapenning im using the latest library from Blynk 0.4.7 Windows 10 and Arduino IDE ver 1.8.1
When i use the MKR1000 with the normal sketchs from Arduino everething is fine.
I will appreciate your help to solve this issue.
Looks like you made the wrong selections for your hardware in the Sketch Builder.
Why don’t you just google for WiFi101?
Just install WiFi101 library…
Hi All.
Sorry that was a lapsus …!
Everything is working now…!
Best Regards and thank you for your help.
