[Solved] "Error processing client command" with setProperty
Hello All,
I thought I’d take advantage of setProperty, but have yet to see it work.
With debug I see the signals sent and in the app I then get the error…
“Error processing client command”
Where am I going wrong? Or maybe it has something to do with BLE? Unfortunately BLE is the only way I can connect without dismantling my hardware.
Hardware:
Nexus 6 with Android 7.0 installed
Sparkfun RedBoard (Uno clone)
Adafruit BlueFruit LE Shield
Big Easy Driver (stepper motor driver – not used in this sketch, but is connected)
Blynk library v0.3.10
Here’s a sketch as an example
// V2   labeledValue, freq = 10sec
// V20  gauge, freq = 10sec
// BLE module
#define BLYNK_DEBUG
#define BLYNK_USE_DIRECT_CONNECT // If trouble connecting trying commenting out
// BLE
// Adafruit Bluefruit LE Shield which using SPI
#include <Adafruit_BLE.h>
#include <Adafruit_BluefruitLE_SPI.h>
#define BLUEFRUIT_SPI_CS 8
#define BLUEFRUIT_SPI_IRQ 7
#define BLUEFRUIT_SPI_RST 4
#define BLUEFRUIT_VERBOSE_MODE false
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxx";
void gaugeColor()
  Blynk.setProperty(V20, "color", "#999999");
void valueLabel()
  Blynk.setProperty(V2, "label", "Hello Label");
int gauge_timer = timer.setInterval(10000, gaugeColor);
int value_timer = timer.setInterval(15000, valueLabel);
  Blynk.begin(auth, ble);
  ble.begin(BLUEFRUIT_VERBOSE_MODE);
  ble.factoryReset(); // Optional but advisable
  ble.setMode(BLUEFRUIT_MODE_DATA);
  while (!ble.isConnected())
    delay(2000);
  Blynk.setProperty(V2, "label", "vDisplay");
  timer.restartTimer(gauge_timer);
  timer.restartTimer(value_timer);
you have two set properties for V2 - did you try just doing one?
Ha – after a while I forget what I tried and didn’t try!
But yeah I did and went back and tried just one setProperty again. Below is a sketch of that.
I don’t know if you noticed but there is an open issue #170 on git hub for multiple setProperty(s) in a row.
// BLE module
#define BLYNK_DEBUG
// BLE
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
void valueLabel()
    delay(2000);
Thanks. We’ll check. I think this related somehow with BLE.
Thanks,
It’s Android app issue - will be fixed with next release.
Looks like its working now with the new release. Thanks!
