[Solved] Error compiling for board Arduino/Genuino Mega or Mega 2560
Hi.
I have a problem compiling my code, can’t find out what the problem is.
I have reinstalled the program and all the lib´s but still the same problem.
Here is the error code, can anybody help ?
“In file included from /Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/WidgetLED.h:13:0,
from /Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/BlynkWidgets.h:10,
from /Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/BlynkSimpleEthernet.h:26,
from /Users/sebastianhorup/Documents/Arduino/Vido/Vido.ino:5:
/Users/sebastianhorup/Documents/Arduino/Vido/Vido.ino: In function ‘void BlynkWidgetWrite30(BlynkReq&, const BlynkParam&)’:
/Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkWidgetBase.h:50:33: error: ‘class WidgetRTC’ has no member named ‘onWrite’
BLYNK_WRITE(pin) { (widget).onWrite(request, param); }
/Users/sebastianhorup/Documents/Arduino/Vido/Vido.ino:13:1: note: in expansion of macro ‘BLYNK_ATTACH_WIDGET’
BLYNK_ATTACH_WIDGET(rtc,V30);
/Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkWidgetBase.h: In instantiation of ‘BlynkAttachWidgetHelper::BlynkAttachWidgetHelper(T&, uint8_t) [with T = WidgetRTC; uint8_t = unsigned char]’:
/Users/sebastianhorup/Documents/Arduino/Vido/Vido.ino:13:1: required from here
/Users/sebastianhorup/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkWidgetBase.h:43:9: error: ‘class WidgetRTC’ has no member named ‘setVPin’
widget.setVPin(vPin);
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.”
Sketch?
RTC is done differently with the latest library and app. See Announcements.
wow, works now :slight_smile: didn’t see that;).
Thanks :pray:
Also for the quick reply! :smiley:
can some one guide me. i had the same problem. i don’t no to solve the problem :sob::sob::sob::sob::sob::sob::sob::sob:
@Muhd_Afiqzul if you genuinely had the same problem then the fix is to use latest libraries and latest example sketch for RTC.
@Muhd_Afiqzul And if for some strange reason that doesn’t work… create a new “Need Help with my Project” topic with MORE details and LESS tears.
