[Solved] DHT11 some time status NaN
Hi
have a nodemcu connected with a dht11.
in the serial log it sometimes shows:
[601332] >vr[00]1
[602560] <[14|00]d[00|08]vw[00]4[00]nan
[602648] <[14|00]e[00|08]vw[00]5[00]nan
[602688] >[14|1B]][00|04]
and in blynk the gauges goes blank.
Could it be something to do with timer setinterval?
And whats the difference for “20000” and “20000L” in setInterval?
here is my code:
#define BLYNK_DEBUG
#include <DHT.h>
#define DHTPIN D5
#define DHTTYPE DHT11
int setTemp = 23;
DHT dht(DHTPIN, DHTTYPE);
float humidity, temp_f; // Values read from sensor
char auth[] = "xxxx"; //insert here your token generated by Blynk
WiFi.mode(WIFI_STA);
Blynk.begin(auth, "xxxx", "xxxx"); //insert here your SSID and password
timer.setInterval(20000, sendData);
timer.setInterval(100000L, sendWifi);
void sendWifi()
  Blynk.virtualWrite(1, map(WiFi.RSSI(), -105, -40, 0, 100) );
BLYNK_WRITE(V6) //temperature slider in app
  setTemp = param.asInt();
void sendData()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
if(t < setTemp) {Blynk.notify("for lav temp");}
//Write values to V04 and V05
Blynk.virtualWrite(4, h);
Blynk.virtualWrite(5, t);
Nan is fine. DHT may fail readings sometimes. You need a check in code
if (isnan(t)) {
    return;
Thx for a quick answer.
looked up your code.
NaN means “not a number”
Use it like the code below?
Seems to work… “return” does that mean its starts from the beginning again?
(Not a coder but here to learn :slight_smile: )
 void sendData()
if (isnan(t)) {
    return;
return; mean return nothing. In other works - stop execution of method.
You should place check before this :
I see, so it wont see a NaN as lower than setTemp.
thx again
It is more complicated. Nan - not a number as you said. This mean behaviour may be not predictable. So t < setTemp could be true or could be false :slight_smile:.
