Greetings,
I’ve been reading a lot here but I can«t manage to find a solution to my problem…
I’m new to Blynk and Arduino and my project was going fine but suddenly it just keeps disconnecting every 5 seconds.
I’ve been trying lots of things to fix it for the past 2 weeks but it doesn’t seem to work.
Would any of you guys lend me a hand fixing this?
#include <ESP8266_Lib.h> //INCLUSÃO DE BIBLIOTECA
#include <BlynkSimpleShieldEsp8266.h> //INCLUSÃO DE BIBLIOTECA
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(15, 14); //PINOS QUE EMULAM A SERIAL (PINO 10 É O RX E PINO 11 É O TX)
#define EspSerial Serial3
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "ZAP-ABC0"; //VARIÁVEL QUE ARMAZENA O NOME DA REDE SEM FIO EM QUE VAI CONECTAR
char pass[] = "437fad4f1857"; //VARIÁVEL QUE ARMAZENA A SENHA DA REDE SEM FIO EM QUE VAI CONECTAR
const int pinoRele1 = 2; //APARTAMENTO AP, 2 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 1
const int pinoRele2 = 3; //APARTAMENTO AQ, 2 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 2
const int pinoRele3 = 4; //APARTAMENTO AR, 2 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 3
const int pinoRele4 = 5; //APARTAMENTO AS, 2 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 4
const int pinoRele5 = 6; //APARTAMENTO AT, 3 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 5
const int pinoRele6 = 7; //APARTAMENTO AU, 3 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 6
const int pinoRele7 = 8; //APARTAMENTO AV, 3 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 7
const int pinoRele8 = 9; //APARTAMENTO AW, 3 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 8
const int pinoRele9 = 10; //APARTAMENTO AX, 4 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 9
const int pinoRele10 = 11; //APARTAMENTO AY, 4 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 10
const int pinoRele11 = 12; //APARTAMENTO AZ, 4 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 11
const int pinoRele12 = 13; //APARTAMENTO BA, 4 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 12
const int pinoRele13 = 22; //APARTAMENTO BB, 5 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 13
const int pinoRele14 = 23; //APARTAMENTO BC, 5 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 14
const int pinoRele15 = 24; //APARTAMENTO BD, 5 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 15
const int pinoRele16 = 25; //APARTAMENTO BE, 5 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 16
const int pinoRele17 = 26; //APARTAMENTO BF, 6 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 17
const int pinoRele18 = 27; //APARTAMENTO BG, 6 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 18
const int pinoRele19 = 28; //APARTAMENTO BH, 6 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 19
const int pinoRele20 = 29; //APARTAMENTO BI, 6 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 20
const int pinoRele21 = 30; //APARTAMENTO BJ, 7 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 21
const int pinoRele22 = 31; //APARTAMENTO BK, 7 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 22
const int pinoRele23 = 32; //APARTAMENTO BL, 7 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 23
const int pinoRele24 = 33; //APARTAMENTO BM, 7 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 24
const int pinoRele25 = 34; //APARTAMENTO BN, 8 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 25
const int pinoRele26 = 35; //APARTAMENTO BO, 8 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 26
const int pinoRele27 = 36; //APARTAMENTO BP, 8 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 27
const int pinoRele28 = 37; //APARTAMENTO BQ, 8 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 28
const int pinoRele29 = 38; //APARTAMENTO BR, 9 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 29
const int pinoRele30 = 39; //APARTAMENTO BS, 9 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 30
const int pinoRele31 = 40; //APARTAMENTO BT, 9 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 31
const int pinoRele32 = 41; //APARTAMENTO BU, 9 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 32
const int pinoRele33 = 42; //APARTAMENTO BV, 10 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 33
const int pinoRele34 = 43; //APARTAMENTO BW, 10 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 34
const int pinoRele35 = 44; //APARTAMENTO BX, 10 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 35
const int pinoRele36 = 45; //APARTAMENTO BY, 10 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 36
const int pinoRele37 = 46; //APARTAMENTO BZ, 11 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 37
const int pinoRele38 = 47; //APARTAMENTO CA, 11 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 38
const int pinoRele39 = 48; //APARTAMENTO CB, 11 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 39
const int pinoRele40 = 49; //APARTAMENTO CC, 11 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 40
const int pinoRele41 = 50; //APARTAMENTO FE, 12 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 41
const int pinoRele42 = 51; //APARTAMENTO FF, 12 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 42
const int pinoRele43 = 52; //APARTAMENTO FG, 12 PISO. DIGITAL UTILIZADO PELO MÓDULO RELÉ 43
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial); //PASSO OS PARÂMETROS PARA A FUNÇÃO
void setup(){
pinMode(pinoRele1, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele2, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele3, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele4, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele5, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele6, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele7, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele8, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele9, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele10, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele11, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele12, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele13, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele14, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele15, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele16, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele17, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele18, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele19, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele20, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele21, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele22, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele23, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele24, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele25, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele26, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele27, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele28, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele29, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele30, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele31, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele32, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele33, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele34, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele35, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele36, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele37, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele38, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele39, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele40, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele41, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele42, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pinoRele43, OUTPUT); //DECLARA O PINO COMO SAÍDA
EspSerial.begin(ESP8266_BAUD); //INICIA A COMUNICAÇÃO COM A TAXA INFORMADA NO ESP8266_BAUD
delay(10); //INTERVALO DE 10 MILISSEGUNDOS
Blynk.begin(auth, wifi, ssid, pass); //INICIALIZA A COMUNICAÇÃO BLYNK INFORMANDO OS PARÂMETROS
digitalWrite(pinoRele1, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele2, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele3, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele4, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele5, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele6, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele7, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele8, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele9, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele10, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele11, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele12, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele13, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele14, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele15, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele16, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele17, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele18, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele19, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele20, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele21, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele22, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele23, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele24, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele25, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele26, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele27, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele28, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele29, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele30, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele31, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele32, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele33, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele34, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele35, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele36, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele37, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele38, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele39, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele40, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele41, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele42, HIGH); //RELÉ INICIA DESLIGADO
digitalWrite(pinoRele43, HIGH); //RELÉ INICIA DESLIGADO
void loop(){
Blynk.run(); //INICIALIZA O BLYNK
