Hi
I would need some help to get working the attached code
It receives a string representing a sensor reading sent from an external mcu to Photon.
If the code running on external mcu detects that some threshold value is exceeded, the external mcu sent a hex value to the Photon’s code so that Photon send an Email.
But it only happens some times immediately after a code was flashed.
#include <blynk.h>
App project setup:
Value Display widget attached to V7
#define BLYNK_PRINT Serial1
//#include <blynk.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxdebe15bca715xxxx";
char Ampstr[6];
int Email_1 =0;
int AlreadySent=0;
void sendAmp()
int i=0;
while ( Serial1.available() && i < 6 )
Ampstr[i] = Serial1.read();
if( Ampstr[i]=='\0' )
{ break;}
i++;
i=0;
Ampstr[5] = '\0';
// Send it to the server
Blynk.virtualWrite(V7, Ampstr);
void SEmail()
while ( Serial1.available()>0)
Email_1= Serial1.read();
if ( Email_1)
{ Blynk.email("Email address ", "High Amps limit reached", "Amps >7.0");
Email_1=0; break;}
Serial1.begin(56700);
delay(5000); // Allow board to settle
Blynk.begin(auth);
timer.setInterval(1000L, sendAmp);
timer.setInterval(20000L, SEmail);
Thanks for some help
