[SOLVED] Changing colour of text
Hi. I am using a labled value widget reading pin V5 every second.
I am using the following sketch to display either “OK” or “EMPTY”. Is there a way to make “OK” white and “EMPTY” appear red?
Thanks.
int sensorVal;
char auth[] = "f685******************************54b";
  Serial1.begin(9600);  // via BT Module
  Blynk.begin(Serial1, auth);  // Connect to App via BT
  pinMode(50, INPUT_PULLUP);
  pinMode(13, OUTPUT);
void atocheck()
  if (digitalRead(50) == 0)
    Blynk.virtualWrite(5, "EMPTY");
    Blynk.virtualWrite(5, "OK");
  atocheck();
Yes
http://docs.blynk.cc/#blynk-main-operations-change-widget-properties
Excellent thank you,
