Board: Arduino UNO
Browser: Chrome 50.0
OS: Windows 10
IDE: codebender
Blynk: v0.3.7 (I use the scripts only, for uploading the sketch I use codebender)
when I run the following command as Administrator
blynk-ser.bat -c COM4
I got the following:
Connecting device at COM4 to blynk-cloud.com:8442... OpenC0C("\\.\COM4", baud=9600, data=8, parity=no, stop=1) - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF Received EOF EVENT_CLOSE InOut() - STOP Disconnect() - OK Connect("blynk-cloud.com", "8442") - OK InOut() START DSR is OFF
On the phone it keeps telling me that:
Your Arduino UNO is not in network
Update 1
I’m trying to switch pin 13 to control the attached led at UNO
Update 2
Installing the library and uploading the sketch via Arduino IDE 1.6.3 works.
Seems that codebender causes the issue
