[Solved] Can't connect to server. Please check your internet connection or try again later
Can’t connect to server. Please check your internet connection or try again later.
I’ve read some of the similar posts. I’m out of the UK now and could not access the blynk in China at the airport via boingo wifi. Now the same in New Zealand via a home router. I tied logging out and back in as per the post but now get user not registered when I try to log back in.
Also tried uninstalling and reinstalling Blynk
Then tried resetting my password as it then said my authentication had failed. Requested a new password which I reset successfully. Now it thinks I am a new users and I have no projects. Strange.
My login email is grant@macs3.freeserve.co.uk
Can you help please.
I
Did you read all the geo-dns posts and fixes?
Probably http://docs.blynk.cc/#troubleshooting-geo-dns-problem
Please try 139.59.206.133
Yep that’s got it. Did you get the ip address knowing I was in NZ or is this an address that normally works anyway? Thanks for the fast response.
this one
