hi
i have a server running on RPI zero which has an wifi dongle and successfully running on and app connected to it , also admin page working fine.
trouble shoot i have done
- my hardware is connected to the WIFI and has taken an IP
- my server is running as my app connected to it also admin page working fine from my laptop.
- my RPI server has ports (22 , 5900) for ssh and vnc , (8080 , 8443) for Blynk exposed.
my sketch is
http://twitter.com/blynk_app
This sketch shows how to read values from Virtual Pins
App project setup:
Slider widget (0...100) on Virtual Pin V1
char auth[] = "6c4c75ae3ca341efb931c70e457fb0ef";
char ssid[] = "HomeWifi";
char pass[] = "a123456789";
// in Blynk app writes values to the Virtual Pin V1
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,222));
i have tried to change blynk.befin with port 8443 also not work and my my serial monitor is just showing Connecting to HomeWifi
is any change to the sketch or settings on the server required ?
thanks in advance
