Hi everyone,
I wrote a simple code to watering my plants. Watering is defined by a frequency (frequence) and a watering period (delai). Both have to be modified by 2 different widget. I use Numeric Imput for now but tried stepper and slider.
I can get the frequency working, but I’m struggling to make the watering period working well. Code below
//*********BRUMISATION***********// int freq; int delai; int timerV0START1; int timerV0START2; int timerV0STOP1; int timerV0STOP2; BLYNK_WRITE(V1){ int delai = param.asInt(); Serial.print(delai); } void brumicycle (){ brumistart(); timerV0STOP1 = timer.setTimeout(delai*1000L, brumistop); timerV0START2 = timer.setTimeout(delai*1000L+5000L, brumistart); timerV0STOP2 = timer.setTimeout(delai*1000L+5000L+delai*1000L, brumistop); } void brumistart(){ Blynk.virtualWrite(V22,0); digitalWrite( waterrelayPin,LOW ); } void brumistop(){ Blynk.virtualWrite(V22,1); digitalWrite( waterrelayPin,HIGH ); } BLYNK_WRITE(V0){ int freq = param.asInt(); if (freq != 0) { timer.deleteTimer(timerV0START1); timerV0START1 = timer.setInterval(freq*60000L, brumicycle); } else { timer.deleteTimer(timerV0START1); } } void setup() { //**********DEBUG CONSOLE**********// Serial.begin(115200); //**********ESP SETUP (OK)**********// Blynk.begin(auth, ssid, pass); delay(200); //**********BME SENSOR (OK)**********// bme.begin(); delay(100); timer.setInterval(1000L, sendSensor); //**********SWITCH HEAT ON/OFF**********// pinMode(heatrelayPin, OUTPUT); //**********SWITCH WATER ON/OFF**********// pinMode(waterrelayPin, OUTPUT); //**********SWITCH LIGHT ON/OFF**********// pinMode(lightrelayPin, OUTPUT); } void loop() { Blynk.run(); timer.run(); }
What I don’t understand is why the brumicycle ()
function does not take the ‘delai’ value into account as it should. If I write int delai = 3;
instead of int delai;
the value of delai in brumicycle ()
will actually be 3, but I won’t be able to change it by the widget.
Hope someone can help !
