[Solved] Button in Push Mode
I have a button on the app on V3 pin in PUSH mode. I try this code and i go crazy…
BLYNK_WRITE(V3) {
  int SwitchStatus = param.asInt();
  if (SwitchStatus == 1) {
    digitalWrite(relay1, LOW);
    lock_v3 = 1;
    Serial.println("on");
    Serial.println(lock_v3);
    digitalWrite(relay1, HIGH);
    lock_v3 = 0;
    Serial.println("off");
The result on serial monitor is this:
Connecting to Telecom-67470869
[30840] Connected to WiFi
[30840] IP: 192.168.1.7
[30840]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.7 on NodeMCU
[30912] Connecting to 192.168.1.3:8442
[31031] Ready (ping: 1ms).
off
0         <---- Initial Sync
on      |
1        |
off      | Long pression on button
0        |
off
0        <---- Release button
Why button pressed and hold, bypass ELSE condition?
What do you expect happens when you push a button in PUSH mode that has 2 states?
Press the button = 1
Release button = 0
Simplfy your code and report the serial montior back here:
BLYNK_WRITE(V3) {
    lock_v3 = param.asInt();
You code is wrong. You are missing brackets for your else statement.
Fixed below
    lock_v3 = 1;
   {     // <- missing
    lock_v3 = 0;
    }// <- missing
Thanks @Fettkeewl damn brackets :joy:
