@NickMurray Can you post your bridge code? Some of us still need enlightenment…
I have bridge working by sending an integer from one Arduino Uno to another Arduino Uno on the same Local Server which I have running on a Raspberry Pi. I have not tried setting up a Bridge to send data in the opposite direction but I imagine it would be done in the same way.
To get the bridge working;
On the sending Arduino
- You do not need the bridge widget on any dashboard, it is just not required
- Before the setup loop —>
WidgetBridge bridge1(V1); - Include in the setup loop —>
while(Blynk.connect() == false){/*wait until connected*/} - Next in the setup loop—>
bridge1.setAuthToken("the_receiving_arduinos_auth_token"); - I have a loop that runs one time every second setup using ‘SimpleTimer’ Library
6)In the one second loop I have —>bridge1.virtualWrite(V1,44);
So for my example I send the value of 44 to Virtual pin1 (V1) of my receiving arduino uno. Obviously I don’t just send a static value of 44 in my actual code but I used that value here to keep it simple.
In the receiving Arduino
- Outside of any other loop —>
BLYNK_WRITE(V1) {LightValue = param.asInt();} - Inside a 1 second loop —>
Blynk.virtualWrite(V25,LightValue);
The value of 44 is handled by the BLYNK_WRITE function where it is written to an integer that I have labelled LightValue then inside a loop that is executed one time every second the LightValue is written to the Blynk App with Blynk.virtualWrite. I display the LightValue on a Value Display Widged that is associated with Virtual Pin V25. In this example it will show the value of 44 on my dashboard
This does work for me. I would like to use the Bridge function more but I have not yet dedicated any more time to it. I would like to send an array of values using the bridge function which I believe is possible but I have not yet been successful in doing that. I hope my description helps you out.
Hi there!
Thanks all people involved helping in this topic, I’ve got my first bridge working!!!
A happy dance in honor of you all!!
