Push notifications work but, emails doesn’t go through…
It used to work before a week, but stopped sending emails from 18th, April…
Note:-
Blynk App on mobile has both Push and Email widgets
I call the Alert() function with this code:
if (rh >= HumidThreshold)
Alert("Humidity", 1, 4);
I’ve set the Buzzer, Push and Email as HIGH…
When the Alert() is executed the Buzzer goes on, I get Push Notification, but I don’t get the email…
Here’s the Alert() code:-
void Alert(String Sensor, int AlertType, int LEDAlert)
if (Buzzer == HIGH)
digitalWrite(buzzPin, HIGH); // Activate Buzzer
if (Push == HIGH)
if (AlertType == 1)
// Blynk.notify(Location + ": Emergency " + Sensor + " Alert!"); // Notification with Location First
Blynk.notify("Emergency: " + Sensor + " Alert! @" + Location); // Notification with Situation First
if (Email == HIGH)
if (AlertType == 1)
Blynk.email("ilak2k@gmail.com", "Emergency: " + Sensor + " Alert! @" + Location, "This is a sensor-triggered alert, from Monitoring System! Investigate specified location");
Blynk.virtualWrite(LEDAlert, 1023); // Write HIGH to Virtual Pin 4
This used to work and now it doesn’t… What might be the issue here???
Hello. First of all - could you please add some tracing or debug info? In other words - are you sure Blynk.email is called? Most probably problem isBlynk.email is not called. Even it was working before.
@Dmitriy I’ve updated my reply with Serial Monitor Screenshot & Alert Code… Why is the email not getting sent? I assure you I’ve included Push Notification Widget & Email Widget…
@Costas Also refer to this Debug Report here…
Disconnects everytime email is sent and i keep getting notifications every 10 seconds… Why would it disconnect while trying to send an email?
That’s the subject we just created… And then…
Blynk.email("ilak2k@gmail.com", szMsg, "This is a sensor-triggered alert, from Monitoring System! Investigate specified location");
So, the message goes like this: Subject:
Emergency: Temperature Alert! @Projector Cabin 456 Content:
That’s an unbelievably small allowed limit for an Email Alert! You guys could increase the email interval to even 5 mins allow more length. An email alert every minute is insane! It helps for testing and stuff. But when it comes to actual usage, such frequent emails is not required…
@Dmitriy It should be Blynk’s limit… I had to reduce length for my Arduino UNO R3 and Particle Photon… That’s 2 different devices and both don’t work for the full length of the message…
Refer to the attached email screenshot here… I assume, most of the length is taken by the subject… And it leaves me with too less for the content…
Server doesn’t have any length limit for email. So I believe this is something hardware specific or blynk library specific. @vshymanskyy should know better.
Yes it did! I use an online bytes calculator… get the required memory in KB and I use it for the message to be handled. Solved! Thank you very much @vshymanskyy
