[SOLVED] Arduino was disconnected. UNO + W5100 Shield
Hi there,
I have problem Arduino not connecting to Blynk server. When I open app on android it always said Your Arduino UNO is not in network and Arduino UNO was disconnected.
I also did portforwarding 8442 to 192.168.1.122 and reboot router many time.
I’m using Arduino UNO (Clone) and W5100 (Clone) shield. Blynk software 0.3.2.
I used example code with only change Token and Enable DEBUG
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use Arduino Ethernet shield (W5100)
 * to connect your project to Blynk.
 * Feel free to apply it to any other example. It's simple!
 * NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
 *       DON'T use them in your sketch directly!
#define BLYNK_DEBUG
#include <Ethernet.h>
char auth[] = "d7421bf0a9244adea9e9c3c5717d6f10";
  Blynk.begin(auth);
  // You can also specify server.
  // For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
  //Blynk.begin(auth, "your_server.com", 8442);
  //Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
here is Serial output
[0] Blynk v0.3.2-beta
[0] Getting IP...
[1520] My IP: 192.168.1.122
[5001] Connecting to cloud.blynk.cc:8442
[5175] <msg 2,1,32
<d7421bf0a9244adea9e9c3c5717d6f10
[5282] >msg 0,1,200
[5283] Ready (ping: 106ms).
[5284] <msg 17,1,101
<ver
[10612] Connecting to cloud.blynk.cc:8442
[10799] <msg 2,1,32
[10952] >msg 0,1,200
[10952] Ready (ping: 151ms).
[10953] <msg 17,2,101
The port forwarding is not needed and we can see it connect fine, but apparently it disconnects soon from what I can see (about 5s).
Have you tried using another power source? Maybe use an adapter instead of USB.
Is that latest library from trunk?
I just download a week ago directly from github master (https://github.com/blynkkk/blynk-library)
Edit: Download 0.3.1 and it’s working. No more Arduino UNO was disconnected.
