Look through all the comments in this sketch and see how you go with it.
/* BlynkifyGPS.ino for https://community.blynk.cc/t/arduino-or-nodemcu-gps-tracking-system-on-map-widget/15739
Sketch for physical GPS device connected to a decent ESP
In map widget set SHOW MY LOCATION to NO unless you also want Smartphone actual location in addition to GPS device + ESP
#include <TinyGPS++.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps; // The TinyGPS++ object
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
char auth[] = "4bb191e6da5a438bb071ecca688732f3";
char ssid[] = "MikroTik Home";
char pass[] = "";
char server[] = "192.168.1.104";
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
bool simulation = false; // set to true for simulation mode, else false. If IranHack is true this must be false
// simulation location is in Egypt
bool IranHack = false; // set to true if GPS is faulty, else false. If simulation is true this must be false
WidgetMap myMap(V5);
Serial.println();
ss.begin(GPSBaud);
Blynk.begin(auth, ssid, pass, server);
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V10, "GPS ERROR"); // Value Display widget set as PUSH frequency on V10
Blynk.virtualWrite(V7, "--------"); // Value Display widget set as PUSH frequency on V7 LATITUDE
Blynk.virtualWrite(V8, "--------"); // Value Display widget set as PUSH frequency on V8 LONGITUDE
delay(1000); // NOT RECOMENDED
if(simulation == true || IranHack == true)
displayInfo();
while (ss.available() > 0) // sketch displays information every time a new sentence is correctly encoded.
if (gps.encode(ss.read()))
displayInfo();
void displayInfo()
if (gps.location.isValid() || simulation == true || IranHack == true)
//move_index++; // moving index, maybe use later
Blynk.virtualWrite(V10, "GPS OK");
float latitude = (gps.location.lat()); // removed , 6 as it can't be used for creating the float
float longitude = (gps.location.lng()); // removed , 6 as it can't be used for creating the float
if(latitude == 0 && longitude == 0 ) // checking to see if the 2 floats variables are correct
Blynk.virtualWrite(V10, "0,0");
if(simulation == true) // location in Egypt
latitude = 30.000123; // also used for debugging
longitude = 30.000987; // also used for debugging
if(IranHack == true)
latitude = 32.644824;
longitude = 51.681746;
Serial.print("LAT: ");
Serial.println(latitude, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V7, String(latitude, 6));
Blynk.virtualWrite(V8, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "GPS_Location");
Serial.print(F("INVALID"));
Blynk.virtualWrite(V10, "GPS INVALID");
Serial.println();
That will be because the main loop() is not really suitable for Blynk.
I just wanted to ensure your GPS and the Map widget were working OK.
Now you know the basic system works the fine tuning can begin.
@ErfanDL this area in loop() is what needs to be fine tuned but it’s a little difficult for me without a GPS device, hence some of the simulation code in the sketch:
displayInfo();
displayInfo();
delay() should not normally be used at all in a Blynk loop() and you should call the GPS function at timed intervals. This might be a little difficult for you as a noob to Arduino and Blynk as you need to be sure the GPS has the full stream before processing the data etc.
With trial and error you could try reducing the 1000 to see if that helps.
If you had more Blynk experience you could change the delay() time with a slider rather than changing the sketch.
@ErfanDL I have created a 30s timed interval to read the GPS data and removed everything from loop().
See how this goes:
/* BlynkifyGPSv2.ino for https://community.blynk.cc/t/arduino-or-nodemcu-gps-tracking-system-on-map-widget/15739
char pass[] = "";
Serial.println();
ss.begin(GPSBaud);
// disable GPS device checking for now
//timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
timer.setInterval(30000L, readGPS); // read GPS data every 30s
readGPS(); // read GPS data on each reboot after connection to Blynk server
void readGPS(){
displayInfo();
displayInfo();
void checkGPS(){
void displayInfo()
Serial.println();
If you are not able to spend time debugging your project yourself you need someone that has similar hardware. Blynkers can offer suggestions based on their Arduino, Blynk and GPS experiences but without sending you dozens and dozens of different sketch versions to test it is very time consuming without the hardware.[quote=“ErfanDL, post:75, topic:15739, full:true”]
whats different between checkgps and readgps ?
[/quote]
checkGPS() was basically to see if you had a working GPS device. readGPS() processes the data from the GPS device.
OK. for now I’m using below sketch. it’s disconnect and reconnecting rapidly but it’s can running my job
char auth[] = "6075f93a98734b3abddb3c3ba6babf08";
char ssid[] = "";
char pass[] = "00471666302047PLX";
Serial.println();
ss.begin(GPSBaud);
void checkGPS(){
//delay(1000); // NOT RECOMENDED
displayInfo();
displayInfo();
void displayInfo()
longitude = 41.681746;
Serial.println();
@ErfanDL reading the spec of your hardware suggests data can be read at 1s intervals.
Go back to the previous sketch where you get no disconnects but no data and try this readGPS():
Paste SM data.
void readGPS(){
long startTime = millis();
long counter = 0;
Serial.print("Started reading GPS data at ");
Serial.println(startTime);
long loopmax = 100L; // max 2,147,483,647 or double this if usigned
while (counter < loopmax)
counter++;
Serial.print(".");
delay(20); // pause 10ms (1s total) 20ms (2s total)
Serial.println();
//counter = 0; // not required as counter is redefined each time readGPS() is called
displayInfo();
displayInfo();
Serial.print("Finished reading GPS data at ");
Serial.print(millis());
Serial.print(" and it took ");
Serial.print(millis() - startTime);
Serial.println("ms.");
Serial.println("-----------------------------------------------------------");
Serial.println();
The constantly reconnecting sketch is not really a solution.
http://twitter.com/blynk_app
Output any data on Map widget!
App project setup:
Map widget on V1
static const int RXPin = 12, TXPin = 13;
TinyGPSPlus gps;
char pass[] = "";
timer.setInterval(1000L, getCoordinates);
myMap.clear();
void readGPS(){
long counter = 0;
counter++;
Serial.print(".");
Serial.println();
displayInfo();
displayInfo();
Serial.println();
void getCoordinates()
myMap.location(1, gps.location.lat(), gps.location.lng(), "value");
App project setup:
Map widget on V1
TinyGPSPlus gps;
char pass[] = "";
void readGPS(){
long counter = 0;
counter++;
Serial.print(".");
Serial.println();
displayInfo();
displayInfo();
Serial.println();
Blynk.virtualWrite(V6, millis() / 1000);
move_index++;
float latitude = (gps.location.lat(), 5);
float longitude = (gps.location.lng(), 4);
Serial.println(String(latitude, 5));
Serial.println(String(longitude, 4));
Blynk.virtualWrite(V7, String(latitude, 5));
Blynk.virtualWrite(V8, String(latitude, 4));
myMap.location(move_index, latitude, longitude, "Iran");
