Every time I go into the app it loads for a second and the Force closes. Does any one have this problem?
Hello. Do you use latest app version?
Yes I do and I think that a dashboard crached the app somehow and now it`s force closing.
Please send me your login, I’ll check. dmitriy@blynk.cc
Hi Clayton,
Seems we fixed this issue, later i’ll send you some build with latest fixes.
By the way, have you used tabs with the project named as ‘Aquarium’?
Yes and after I created the tabs I got the problem.
Yep, we see it. Have you removed them before the problem occured?
I could not because as soon as I created the widget the app force closed and I could not deleted them.
Hm, have you send that first force closed report to the google play? I don’t see currently Tabs widget in this project, but i’m sure it was there, but somehow it was removed, which caused crashes on your side. Does the app uses a stable internet connection? Maybe the first problem were caused by some internet lagging, and not syncing of the tabs widgets with the server.
No I did not send the report to google play. I has always worked but today it wouldn`t start.
Oh thank-you it worked.
