[SOLVED] App crashes when trying to add Power
I ve tried adding power via widget placement and through the main menu. It hesitates then crashes. iPhone 6S with latest iOS. Cellular and wifi connection. Hard and soft restarts, reinstall ineffectual.
Noticed the same problem here. iPhone 6
Same problem on IPhone 6s ios 9.3. Crashes from main screen and from adding widget window. Current power rate 1600. App ver 2.0. Soft IPhone restarts, and app reinstall ineffectual.
@Northernboy @47degreesnorth @Mykola guys, could you please check again? Look like it was Apple issue. It should be fixed right now.
Working now. Thanks for fixing it right away
It works. Thank you for rapid fix.
