[SOLVED] API on local Blynk server
I’m trying to configure a dashboard to integrate value from my local Blynk server. I red http://docs.blynkapi.apiary.io and tried with freeboard but no reply from my local server.
My android app is working fine.
To test my connection, I tried with
curl --include ‘http://xxxx.com:8442/myauthtoken/project
where xxxx.com is my server and myautoken is my private auth token with not luck
curl: (52) Empty reply from server
So obviously, I have something wrong…
Can you point me to any resources to help me with api and blynk on a local server?
Thanks to all.
EDIT:
ok it’s working but i had to change port from 8442 to 8080 and restart server
Correct. HTTP port is 8080.
