Hello all.
I am having an issue with my RTC and i can not work it out. Like everybody else that has issues i dont sync and get a time of 0:0:0 and a date of 1970.
I have tried a lot of different things and i just can not get it to work inside my full code. I can take just the RTC part of it and it works fine but when added with the full code it dosent sync. Although it looks like i get a time sync to start with but it disapears.
Any help would be great.
#include "arduino.h"
// #region Blynk & Esp8266 Setup.
#include <ESP8266_Lib.h>
// Blynk Project Auth Token from the Blynk App.
char auth[] = "????????";
// WiFi AP Settings.
char ssid[] = "ubnt-pico";
char pass[] = "XXXXX";
// Set ESP8266 Serial object
#define EspSerial Serial
// Software serial for communication with ESP8266
// #include <SoftwareSerial.h>
// SoftwareSerial EspSerial(8, 9); // RX, TX
// ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// #endregion
// #region DHT22 Sensor Setup
// #include <DHT.h>
// #define DHTPIN 7
// #define DHTTYPE DHT22
// DHT dht(DHTPIN, DHTTYPE);
// float h = dht.readHumidity();
// float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
// #endregion
// #region DS18B20 Sensor Setup
#include <OneWire.h>
// DS18S20 Temperature chip i/o on pin 10
#define ONE_WIRE_BUS 10
// oneWire instance to communicate with any OneWire devices
// Pass oneWire reference to Dallas Temperature.
// #endregion
// #region RTC
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
// #endregion
// #region LCD & Blynk LCD
#include <LiquidCrystal.h>
// initialize interface pins for LCD
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
WidgetLCD blynkLCD(V20);
// #endregion
// #region On Timer Function
void myTimerEvent()
Blynk.virtualWrite(V6, millis() / 1000);
// #endregion
// #region DHT Sensor Function
// void sendDHT()
// if (isnan(h) || isnan(t)) {
// Serial.println("Failed to read from DHT sensor!");
// return;
// Blynk.virtualWrite(V2, t);
// Blynk.virtualWrite(V3, h);
// Blynk.virtualWrite(V7, t);
// Blynk.virtualWrite(V8, h);
// #endregion
// #region DS18B20 Sensor Function
void sendDS18B20()
//to issue a global temperature;
// request to all devices on the bus
// Send the command to get temperature readings
// Output To Blynk
Blynk.virtualWrite(V4, sensors.getTempCByIndex(0));
Blynk.virtualWrite(V5, sensors.getTempCByIndex(1));
Blynk.virtualWrite(V9, sensors.getTempCByIndex(0));
Blynk.virtualWrite(V10, sensors.getTempCByIndex(1));
// #endregion
// #region LCD & Serial Functions
// #region LCD Start
void startLCD()
lcd.begin(20, 4);
lcd.clear();
lcd.setCursor(5,1);
lcd.print("WELCOME TO");
lcd.setCursor(0,2);
lcd.print("TRIPPLE B DISTILLERY");
blynkLCD.clear();
blynkLCD.print(0, 0, "Welcome To");
blynkLCD.print(0, 1, "Tripple B");
// #endregion LCD Start
// #region LCD Regular Update Output
void timeLCD()
lcd.clear();
lcd.noBlink();
lcd.setCursor(0,1);
lcd.print("Time:");
lcd.setCursor(7,1);
lcd.print(currentTime);
lcd.setCursor(0,2);
lcd.print("Date:");
lcd.setCursor(7,2);
lcd.print(currentDate);
void tempsLCD()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Ambiant ");
lcd.setCursor(13,0);
// lcd.print(t);
lcd.setCursor(18,0);
lcd.print(" C");
lcd.setCursor(0,1);
lcd.print("Humidity ");
lcd.setCursor(13,1);
// lcd.print(h);
lcd.setCursor(18,1);
lcd.print(" %");
lcd.setCursor(0,2);
lcd.print("Fermenter 1 ");
lcd.setCursor(13,2);
lcd.print(sensors.getTempCByIndex(0));
lcd.setCursor(18,2);
lcd.print(" C");
lcd.setCursor(0,3);
lcd.print("Fermenter 2 ");
lcd.setCursor(13,3);
lcd.print(sensors.getTempCByIndex(1));
lcd.setCursor(18,3);
lcd.print(" C");
void clockDisplay()
blynkLCD.clear();
blynkLCD.print(0, 0, "Time:");
blynkLCD.print(6, 0, currentTime);
blynkLCD.print(0, 1, "Date:");
blynkLCD.print(6, 1, currentDate);
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// #endregion LCD Regular Update Output
// #region Serial Monitor Outputs
// void serialDHT()
// Serial.print("DHT22");
// Serial.println();
// Serial.print("Temperature: ");
// // Serial.print(t);
// Serial.print(" *C ");
// Serial.print("Humidity: ");
// // Serial.print(h);
// Serial.print(" %\t");
void serialDS18B20()
Serial.println("");
Serial.println("DS18B20");
Serial.print("Fermenter 1 is: ");
Serial.println(sensors.getTempCByIndex(0));
Serial.print("Fermenter 2 is: ");
Serial.println(sensors.getTempCByIndex(1));
Serial.println("");
void serialCLOCKOUT()
Serial.println("");
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println("");
// #endregion Serial Monitor Outputs
// #endregion
// Debug console &ESP8266 baud rate
Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
// Begin synchronizing and starting sensors
rtc.begin();
// dht.begin();
sensors.begin();
// Timers
timer.setInterval(1000, myTimerEvent); //Send runtime every sec to blynk
timer.setTimeout(5000, startLCD); //LCD Start
timer.setInterval(4000, sendDS18B20); //Send DS18B20 data every 4 sec to blynk
// timer.setInterval(5000, sendDHT); //Send DHT data every 5 sec to blynk
timer.setInterval(10000, clockDisplay); //Update blynk lcd time every 10 sec
timer.setInterval(4500, serialDS18B20); //Update serial mon data every 4.5 sec
// timer.setInterval(5500, serialDHT); //Update serial mon data every 5.5 sec
timer.setInterval(10000, serialCLOCKOUT); //Update serial mon data every 6.5 sec
timer.setInterval(5000, timeLCD); //Update LCD time every 5 sec
timer.setInterval(10000, tempsLCD); //Update LCD temps every 10 sec
