[SOLVED] Alternatives to delay() - SimpleTimer isn't enough
@Jamin here is what i want to happen
CASE 1 when the V1 goes HIGH
  1. Turn on the transistor on(HIGH) that is on pin A4
  2. set the PWM value on pin D11 = 255
  3. Turn of the transistor (LOW) after the servo has reached the desired position(which takes about 1500 milliseconds )
    CASE 2 when V1 goes LOW
  4. Turn on the transistor (HIGH)
  5. Set the PWM value on pin D11 = 10
  6. Turn of the transistor after 1500 milliseconds
Yes, English is not my first language so i overlook it when i am in a hurry
Sorry, I will take care of this in future.
what is easy to understand and implement SimpleTimer or millis()?
I hate millis()
Simpletimer is so… Simple…
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use ESP8266 Shield (with AT commands)
 * to connect your project to Blynk.
 * WARNING!
 *   It's rather tricky to get it working, please read this article:
 *   https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
 * Change WiFi ssid, pass, and Blynk auth token to run :)
 * Feel free to apply it to any other example. It's simple!
#include <ESP8266_Lib.h>
#include<Servo.h>
char auth[] = "auth";
char ssid[] = "Dreamerz";
char pass[] = "pass";
#define EspSerial Serial
Servo servo;
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
BLYNK_WRITE(V1) {
if ( param.asInt()== 1 ) {
  void enable(timer);
  digitalWrite(18, HIGH);
  servo.write(255);
   ??? //replace this with a function that can execute the following after 2 seconds
  digitalWrite(18, LOW);
BLYNK_WRITE(V1)
{ if ( param.asInt() == 0 ) {
  void enable(timer);
  servo.write(10);
  pinMode(18,OUTPUT);
  timer.setTimeout(2000, repeatMe);
  // Set console baud rate
  // Set ESP8266 baud rate
void loop(){
help please. not able to understand simple timer
@Costas @Jamin
Dont spam the forums with duplicate posts/threads
You ask a question once. If someone does not reply, do not make more threads about the same question.
I would like to point out that it is a public holiday long weekend here in New Zealand. It’s summer and im going to the beach.
Here is your answer, it compiles but untested. Im not going to be around for 24 hours to help but someone else here might.
#include <Servo.h>
Servo servo;
// THIS IS A FUNCTION WHICH YOU CAN PASS AND
// ARGUMENT TO, AND CAN BE USED LOADS OF TIMES
// QUICKLY AND EASILY. YOU SHOULD ALWAYS BUILD
// FUNCTIONS TO DO REPEATED TASKS
void servo_ON(int data) {
  delay(10); // NO MORE THAN 25ms is OKAY
  servo.write(data); // PASSING data TO THE servo.write() COMMAND
// THE SIMPLE OFF FUNCTION. THIS ONE CANT HAVE AN ARGUMENT
// BECAUSE IT IS A CALLBACK FOR THE TIMER. WHEN THE setTimeout()
// COMPLETES, IT CALLS THIS FUNCTION
void servo_OFF() {
BLYNK_WRITE(V1) {
  if ( param.asInt() ) {
    servo_ON(255); // ENTER MOVEMENT VALUE AS ARGUMENT
    timer.setTimeout(1500, servo_OFF); // AFTER 1500ms (1.5s), RUN servo_OFF() ONCE
    servo_ON(10); // ENTER MOVEMENT VALUE AS ARGUMENT
    pinMode(18, OUTPUT);
So simple :slight_smile:
Enjoy the beach @Jamin
@Jamin thank you so much. i won’t spam the forums again. SORRY!!
