Soil Moisture Sensor with gauge
Also
Should this:
sensorValuePercent = (300/1023) * 100;
Not be:
sensorValuePercent = (Sensorvalue/1023) * 100;
Mark, what is the raw values for analogread(A0) dry and wet?
dry is 1023 instead of 0
wet is 0 instead of 1023
int Sensorvalue=0;
int sensorPin=A0;
int sensorValuePercent=0;
WidgetLED led1(V1);
WidgetLED led2(V2);
char auth[] = "6044f1c858a547d5a54cf14a1287de89";
  DebugSerial.begin(9600);
timer.setInterval(3000L, blinkLedWidget);
  Blynk.begin(Serial, auth);
void blinkLedWidget()
Blynk.virtualWrite(V5, analogRead(A0) );
 Sensorvalue = map(Sensorvalue, 0,1023,0,1023);
sensorValuePercent = (Sensorvalue/1023)* 100; // In Prozent
Does not work with blynk
It doesn’t work because you do not have any code to obtain the SensorValue.
Directly after:
add;
SensorValue = analogRead(A0);
Does not work even with dry 1023 and with moist 0
Home now, busy checking.
try this:
  Sensorvalue = analogRead(A0);
  Sensorvalue = map(Sensorvalue, 0, 1023, 1023, 0);
  sensorValuePercent = (Sensorvalue / 1023) * 100; // In Prozent
  Blynk.virtualWrite(V5, Sensorvalue);
:smiley: THANK YOU it works now as I would like to thank you again
This works now (I’ve added wifi connection details etc as I don’t use serial connection to blynk)
When the fakesensor (I don’t have a moisture sensor handy) value is 0 the gauge widget shows 1023 (full) and as the fakesensor value increases the gauge decreases. (how many posts are needed for a simple remapping…)
//#include <SoftwareSerial.h>
//SoftwareSerial DebugSerial(2, 3); // RX, TX
//#define BLYNK_PRINT DebugSerial
//#include <BlynkSimpleStream.h>
#include <WiFiClient.h>
int Sensorvalue = 0;
int sensorPin = A0;
int sensorValuePercent = 0;
int FakeSensorvalue = 0;
int i = 0;
WidgetLED led1(V1);
WidgetLED led2(V2);
SimpleTimer faketimer;
char auth[] = "My Auth";  //Insert Your Auth Code Here
char ssid[] = "My SSID;                      //WiFi SSID
char pass[] = "My PSK";                       //WiFi Key / Password
IPAddress server_ip (192, 168, 1, 00;            //insert local server IP address here
WiFiClient espClient;
  // Connect to WiFi network (DHCP Mode)
  WiFi.begin(ssid, pass);
  Serial.print("\n\r \n\rWorking to connect");
  // Wait for connection
  while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
  Blynk.config(auth, server_ip); //local server connection string
  //for Blynk cloud uncomment below
  // Blynk.config(auth);
  while (Blynk.connect() == false) {}
  //DebugSerial.begin(9600);
  faketimer.setInterval(1000L, loopsensor); //need this to simulate the sensor
  //Blynk.begin(Serial, auth);
  //Sensorvalue = analogRead(A0);
  Sensorvalue = FakeSensorvalue;
  Blynk.virtualWrite(V6, FakeSensorvalue); //Just to see the raw value
  Serial.print("Sensor Val: ");
  Serial.println(Sensorvalue);
  Serial.print("Fake Sensor Val: ");
  Serial.println(FakeSensorvalue);
  faketimer.run();
void loopsensor() {
  FakeSensorvalue = FakeSensorvalue + 1;
  if (FakeSensorvalue == 1023) FakeSensorvalue = 0;
Ignore the other buttons. the value display is V6 and the gauge is V5.
hey please can u share with me the last form of the code that worked i amm doing a plant watering project and i am facing same problem as you
hello what do you mean I’ve solved the problem with map
<<<sensorValue = analogRead(sensorPin);
sensorValue = map(sensorValue, 0, 1023, 1023, 0);
sensorValuePercent = (sensorValue / 1023) * 100;
Serial.print (String ("Bodenfeuchte ist : ") + sensorValue = analogRead(sensorPin));
Blynk.virtualWrite(V7, sensorValue);>>>
can u share the whole code please
the code runs with fishno board
#include <OneWire.h>
#include <Fishino.h>
#include <BlynkSimpleFishino.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "962a607a6a01458fbf5c3437aexxxxxx";
#define ONE_WIRE_BUS 2
float tempout = 0;
char Date[16];
char Time[16];
int sensorValue = 0;
int sensorPin = A0;
WidgetRTC rtc;
void clockdata()
  sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
  Serial.print("Uhrzeit und Datum ");
  Serial.print(Time);
  Serial.print(" ");
  Serial.print(Date);
  Serial.println();
  Blynk.virtualWrite(V1, Time);
  Blynk.virtualWrite(V2, Date);
void Twitter(){
  Blynk.tweet (String ("Temperatur ist : ") + sensors.getTempCByIndex(0) + "°C / Bodenfeuchte ist : " + sensorValue + "% um " + (Time) + " am " + (Date));
void Bodenfeucht(){
void Temperaturmessung(){
  tempout = (sensors.getTempCByIndex(0));
  Serial.print (String ("Temperatur ist : ") + sensors.getTempCByIndex(0));
  Blynk.virtualWrite(V4, tempout);
  if (tempout < 9.99) {
    Blynk.setProperty(V4, "label", "arsch kalt °C");
  if (tempout > 10 && tempout < 19) {
    Blynk.setProperty(V4, "label", "Temperatur normal °C");
  if (tempout > 20 && tempout < 69.99) {
    Blynk.setProperty(V4, "label", "schön warm °C");
rtc.begin();
timer.setInterval(1000, clockdata);
timer.setInterval(1000, Bodenfeucht);
timer.setInterval(1000, Temperaturmessung);
timer.setInterval(15000, Twitter);
Blynk.begin(auth, "");
Well, digging the one year old topic is usually bad thing to do, but in this case, response was just brilliant, fast and precise.
Hats off to you, @markop!
A post was split to a new topic: I need a help regarding my project
