Sliders and ZERGBA Read and Write Values
I have an RGB lighting application in which I would like the user to be able to use both the ZERGBA and sliders to change the color of the LEDs. The controller the app connects to also has a touch color wheel. What I want to do is keep the app and controller in sync, as well as the sliders and ZERGBA. Is there any way to get the sliders to both read and write a value so that the controller or ZERGBA could cause the sliders to move to the correct position? I would also like the ZERGBA to update it’s location if the controller or sliders tell it.
The reason for this is so that the controller could sync the app after disconnection to the controller’s saved state.
Thank you,
Regards,
Tom
Right now this widget is not capable of syncing back from hardware
Probably more under the suggestion category at this point then.
Thank you,
Tom
That’s not true.
@tommyvdp you can sync zergba state( on Android inly) and slider states with Blynk.virtualWrite() command. Also state is always synced on activate.
