With just a arduino card connected to pc i do sketch to test a slider wadget , to start easy programming.
Configure slider on blynk as below
Slider V2, from 0 to 200
Use pin 13 because it has a led in arduino board
Condition
If V2 slider >100 led pin 13 on
char auth[] = " ";
void moveControl(int x)
if(x>= 100) //is
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
pinMode(13,OUTPUT);
BLYNK_WRITE(V2)
int x = param.asInt();
moveControl(x);
