Slider value display issue with % suffix (on iOS)
Blynk IoT app 3.4.6 (0)
iPadOS 15.7
When using horizontal slider widget with Datastream data type set to “Integer” and Units set to “Percent, %”, I get the following problem:
The number displays fine on startup, but when I change the value by operating the slider, the number displays “3…” rather than “30%”.
I tried this with left and right-alignment of the value and with large and small sliders with same behavior.
I attempted to force system font size to smallest setting, with no benefit.
I have the same display problem on another Datastream when I use the Fahrenheit unit.
@Eugene one for you…
Thanks for the report, we’ll fix.
Note that you could use a separate widget to display datastream value (and fine tune its display).
Thank you. That work-around is fine if I send values while sliding (not on release).
Side note - the “Title (Optional)” placeholder for the horizontal slider is misspelled as “Tite (Optional)”.
Hello @Eugene,
Has this already been fixed? I faced the same issue on ios.
Hello, @sparks fix hasn’t been released yet
