Sketch CAM Resolution/Quality
Hey Folks
Wondering if anyone could assist me in finding the camera quality in this sketch. Im trying to lower the quality because it seems there is some serious delay / jumps in streaming the device from my phone.
#include <EasyDDNS.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
//#include <AutoWifi.h>
#include "SimStreamer.h"
#include "OV2640Streamer.h"
#include "OV2640.h"
#include "CRtspSession.h"
char auth[] = "**************************";
char ssid[] = "**************************";
char pass[] = "**************************";
// This board has slightly different GPIO bindings (and lots more RAM)
// uncomment to use
// #define USEBOARD_TTGO_T
 #define USEBOARD_AITHINKER
#ifndef USEBOARD_AITHINKER
//#define ENABLE_OLED //if want use oled ,turn on thi macro
#endif
// #define SOFTAP_MODE // If you want to run our own softap turn this on
#define ENABLE_WEBSERVER
#define ENABLE_RTSPSERVER
// If your board has a GPIO which is attached to a button, uncomment the following line
// and adjust the GPIO number as needed.  If that button is held down during boot the device
// will factory reset.
#define FACTORYRESET_BUTTON 32
#endif
#ifdef ENABLE_OLED
#include "SSD1306.h"
#define OLED_ADDRESS 0x3c
#ifdef USEBOARD_TTGO_T
#define I2C_SDA 21
#define I2C_SCL 22
#else
#define I2C_SDA 14
#define I2C_SCL 13
#endif
SSD1306Wire display(OLED_ADDRESS, I2C_SDA, I2C_SCL, GEOMETRY_128_32);
bool hasDisplay; // we probe for the device at runtime
#endif
OV2640 cam;
#ifdef ENABLE_WEBSERVER
WebServer server(8080);
#endif
#ifdef ENABLE_RTSPSERVER
WiFiServer rtspServer(8554);
#endif
#ifdef SOFTAP_MODE
IPAddress apIP = IPAddress(192, 168, 1, 1);
#else
#endif
void handle_jpg_stream(void)
    WiFiClient client = server.client();
    String response = "HTTP/1.1 200 OK\r\n";
    response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
    server.sendContent(response);
    while (1)
        cam.run();
        if (!client.connected())
            break;
        response = "--frame\r\n";
        response += "Content-Type: image/jpeg\r\n\r\n";
        client.write((char *)cam.getfb(), cam.getSize());
        server.sendContent("\r\n");
            break;
void handle_jpg(void)
    cam.run();
        return;
    response += "Content-disposition: inline; filename=capture.jpg\r\n";
    response += "Content-type: image/jpeg\r\n\r\n";
void handleNotFound()
    String message = "Server is running!\n\n";
    message += "URI: ";
    message += server.uri();
    message += "\nMethod: ";
    message += (server.method() == HTTP_GET) ? "GET" : "POST";
    message += "\nArguments: ";
    message += server.args();
    message += "\n";
    server.send(200, "text/plain", message);
#endif
void lcdMessage(String msg)
  #ifdef ENABLE_OLED
    if(hasDisplay) {
        display.clear();
        display.drawString(128 / 2, 32 / 2, msg);
        display.display();
  #endif
  EasyDDNS.service("noip");    // Enter your DDNS Service Name - "duckdns" / "noip"
  EasyDDNS.client("**************************.ddns.net","**************************","**************************");    // Enter ddns Domain & Username & Password | Example - "esp.duckdns.org","username", "password"
  #ifdef ENABLE_OLED
    hasDisplay = display.init();
    if(hasDisplay) {
        display.flipScreenVertically();
        display.setFont(ArialMT_Plain_16);
        display.setTextAlignment(TEXT_ALIGN_CENTER);
  #endif
    lcdMessage("booting");
    while (!Serial)
    int camInit =
        cam.init(esp32cam_ttgo_t_config);
#else
#ifdef USEBOARD_AITHINKER
        cam.init(esp32cam_aithinker_config);
#else
        cam.init(esp32cam_config);
#endif
#endif
    Serial.printf("Camera init returned %d\n", camInit);
    IPAddress ip;
#ifdef SOFTAP_MODE
    const char *hostname = "devcam";
    // WiFi.hostname(hostname); // FIXME - find out why undefined
    lcdMessage("starting softAP");
    WiFi.mode(WIFI_AP);
    WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
    bool result = WiFi.softAP(hostname, "12345678", 1, 0);
    if (!result)
        Serial.println("AP Config failed.");
        return;
        Serial.println("AP Config Success.");
        Serial.print("AP MAC: ");
        Serial.println(WiFi.softAPmacAddress());
        ip = WiFi.softAPIP();
#else
    WiFi.begin(ssid, pass);
    while (WiFi.status() != WL_CONNECTED)
        delay(500);
        Serial.print(F("."));
    ip = WiFi.localIP();
    Serial.println(F("WiFi connected"));
    Serial.println(ip);
#endif
    lcdMessage(ip.toString());
    server.on("/", HTTP_GET, handle_jpg_stream);
    server.on("/jpg", HTTP_GET, handle_jpg);
    server.onNotFound(handleNotFound);
    server.begin();
#endif
    rtspServer.begin();
#endif
CStreamer *streamer;
CRtspSession *session;
WiFiClient client; // FIXME, support multiple clients
  EasyDDNS.update(10000); // Check for New Ip Every 10 Seconds.
    server.handleClient();
#endif
    uint32_t msecPerFrame = 100;
    static uint32_t lastimage = millis();
    // If we have an active client connection, just service that until gone
    // (FIXME - support multiple simultaneous clients)
    if(session) {
        session->handleRequests(0); // we don't use a timeout here,
        // instead we send only if we have new enough frames
        uint32_t now = millis();
        if(now > lastimage + msecPerFrame || now < lastimage) { // handle clock rollover
            session->broadcastCurrentFrame(now);
            lastimage = now;
            // check if we are overrunning our max frame rate
            now = millis();
            if(now > lastimage + msecPerFrame)
                printf("warning exceeding max frame rate of %d ms\n", now - lastimage);
        if(session->m_stopped) {
            delete session;
            delete streamer;
            session = NULL;
            streamer = NULL;
    else {
        client = rtspServer.accept();
        if(client) {
            //streamer = new SimStreamer(&client, true);             // our streamer for UDP/TCP based RTP transport
            streamer = new OV2640Streamer(&client, cam);             // our streamer for UDP/TCP based RTP transport
            session = new CRtspSession(&client, streamer); // our threads RTSP session and state
#endif
This line tells the compiler that you’re using the AiThinker board:
and these lines tell the compiler which settings to use for that board:
#else
The tricky bit is that the esp32cam_aithinker_config settings are embedded in the OV2640.cpp library file, which you need to edit.
when you open up that file you’ll see something like this:
camera_config_t esp32cam_aithinker_config{
    .pin_pwdn = 32,
    .pin_reset = -1,
    .pin_xclk = 0,
    .pin_sscb_sda = 26,
    .pin_sscb_scl = 27,
    // Note: LED GPIO is apparently 4 not sure where that goes
    // per https://github.com/donny681/ESP32_CAMERA_QR/blob/e4ef44549876457cd841f33a0892c82a71f35358/main/led.c
    .pin_d7 = 35,
    .pin_d6 = 34,
    .pin_d5 = 39,
    .pin_d4 = 36,
    .pin_d3 = 21,
    .pin_d2 = 19,
    .pin_d1 = 18,
    .pin_d0 = 5,
    .pin_vsync = 25,
    .pin_href = 23,
    .pin_pclk = 22,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_1,
    .ledc_channel = LEDC_CHANNEL_1,
    .pixel_format = PIXFORMAT_JPEG,
    // .frame_size = FRAMESIZE_UXGA, // needs 234K of framebuffer space
    // .frame_size = FRAMESIZE_SXGA, // needs 160K for framebuffer
    // .frame_size = FRAMESIZE_XGA, // needs 96K or even smaller FRAMESIZE_SVGA - can work if using only 1 fb
    .frame_size = FRAMESIZE_SVGA,
    .jpeg_quality = 12, //0-63 lower numbers are higher quality
    .fb_count = 2       // if more than one i2s runs in continous mode.  Use only with jpeg
The important bit of this is towards the end…
so, it seems that the default is SVGA, which is the lowest of the available resolutions:
SVGA -  800 x 600
XGA  - 1024 x 768
SXGA - 1280 x 1024
UXGA - 1600 x 1200
I’m guessing therefore that it’s the jpeg_quality that you need to change, to a larger number than the default. When you’re making these changes, make sure that it’s the camera_config_t esp32cam_aithinker_config section of the file that you’re editing.
Thank you so much Pete you are a champion!! i set it now and it works. Thanks so much!
Out of interest, what setting did you choose?
What sort of results are you seeing?
So i did notice that the device was NOT connecting to the AP(access point) closest to me. its weird considering all SSID’s and Passwords are the same.
With regards to quality i set the jpeg_quality = 48 and i changed the default SVGA to VGA which is a lower res.
It streams really well without an Ariel
Okay, didn’t realise that VGA was an option.
With the access point issue, check that SSID and password are exactly the same (they are case sensitive) and that the channel width settings are the same as your other devices.
Obviously the ESP32 can only use 2.4GHz, so if you’re broadcasting the same SSID on both bands from your nearest AP then it might be confusing the device.
