I’m using SimpleTimer Timeout function to open/close a relay. The problem I’m having is the 15 second timer doesn’t reset. For instance if I tigger V6, wait 5 seconds, trigger V7, wait 5 seconds, and trigger V6 again then V6 will only stay active for 5 more seconds not another 15 seconds like I want. I tried to get the reset or disable function to work but can’t seem to do it. Any suggestions? Thanks
BLYNK_WRITE(V6) {
Serial.println("Relay Closing...");
digitalWrite(4, HIGH);
digitalWrite(5, LOW);
timer.setTimeout(15000, CloseRelay);
void CloseRelay() {
digitalWrite(5, HIGH);
Blynk.virtualWrite(V6, HIGH);
Serial.println("Relay Closed");
BLYNK_WRITE(V7) {
Serial.println("Relay Opening...");
digitalWrite(4, LOW);
timer.setTimeout(15000, OpenRelay);
void OpenRelay() {
Blynk.virtualWrite(V7, HIGH);
Serial.println("Relay Opened");
