simpleTimer for relay or Mosfet
Hello everybody
I am very new to programing, hence due to lack of knowledge & experience run into trubles.
Your help is highly appreciated!
I am trying to set a mosfet (or a relay) to go ON for 30 seconds
than oFF for 250 (1/4 of a second 25%) and than back on for 30 seconds &off for 250 (1/4 of a second thats the whole loop
Used the example sketch below, it outputs that loop (30 seconds on 1/4 second off)
but the the problem is i cant turn it off completely. namely, when i press the digital button to OFF it shots down for 30 seconds and than turns on and it starts over
How to add a function which will enable to complete shot down the d4 pin
Wemos D1R1
Thanks in Advance!
THANKS VERY MUCH!
@Arrow008 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
