Simple push button notification from app only
Hi!
How can I setup and Eventor to send a notification when D1 is low or high?
In the widget I can only use Virtual pins, how can I map a Digital to Virtual pin?
i mainly want to use the app for events, and minimal coding if possible (for now).
Thank you for helping this noobie! :slight_smile:
Only by writing the values to vPIN.
How to forward values of D1 to V1?
I could not find a sample code.
edit:
is the “Blynk.virtualWrite” the one I need?
This is what I made so far:
void test1()
Blynk.virtualWrite(1,digitalRead(1)); //Assign D1 value (low/high) to V1
Yes. But it is highly advisable to use timers.
  timer.setInterval(15000,  sendDataDHT);
  timer.setInterval(60000,  sendDataBMP);
  timer.setInterval(7000,  sendDataOPS);
  timer.setInterval(2000,  sendDataPID);
void sendDataDHT()
   int d =  digitalRead(1);
   Blynk.virtualWrite(V1, d);
... Etc.
I’d also recommend sending the notification from the code rather than from using Eventor.
This is what I ended up with:
void sendData()
   int d = digitalRead(D1);
  pinMode(D1, INPUT_PULLUP);
  timer.setInterval(1000L, sendData);
It is working yay!
Although I do have a problem, but I am not sure if it is related to the code. When I add a new widget from the app, I no longer receive values from the board (NodeMCU v3), even if I restart the app, but when I reset the board it self then it works again.
