I have moved it to the top but it still has a connection error
#define BLYNK_TEMPLATE_ID "TMPLrKAvPedF"
#define BLYNK_DEVICE_NAME "Dev 2 GSM"
#define BLYNK_AUTH_TOKEN "OTQ0an_SSlPvkE6r7fZU46h2IZx0mxPi"
#define BLYNK_DEBUG
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "lte.vodacom.za";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
#include <DHT.h>
#define DHT11_PIN 4
#define DHTTYPE DHT11
DHT dht(DHT11_PIN, DHTTYPE);
#define INTERVAL 1000L
* This function sends Arduino's up time every second to Virtual Pin.
* In the app, Widget's reading frequency should be set to PUSH. This means
* that you define how often to send data to Blynk App.
void SendDhtData()
//Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
//Read temperature as Celsius (the default)
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
//Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.println(t);
Serial.print("Humidity: ");
Serial.println(h);
Serial.println("------------------------------------------");
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V1, h);
* setup() function
// Set GSM module baud rate
SerialAT.begin(9600);
//SerialAT.begin(9600,SWSERIAL_8N1,D3,D4);
delay(3000);
dht.begin();
//modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(auth, modem, apn, user, pass, "blynk-cloud.com", 8080);
timer.setInterval(INTERVAL, SendDhtData);
* loop() function
//modem.restart();
Blynk.begin(auth, modem, apn, user, pass, "blynk.cloud", 8080);
I managed to get it to connect with a global sim card, the issue was with Vodacom.
I now have a error
13:56:03.389 → [33099] >ny3.blynk.cloud[00]80
13:56:03.389 → [33099] Redirecting to ny3.blynk.cloud:80
13:56:03.482 → [33185] Connecting to ny3.blynk.cloud:80
13:56:04.700 → [34425] <[1D|00|01|00] JKKBMrNTb6SM12jWdBtilx6gEFzhASCd
13:56:05.447 → [35168] >[00|00|01|00|C8]
13:56:05.447 → [35169] Ready (ping: 641ms).
13:56:05.447 → [35170] Free RAM: 598
13:56:05.447 → [35171] >[14|00|01|00|08]
13:56:05.447 → [35173] >pm[00]3[00]out
13:56:05.541 → [35236] <[11|00|02|00|8C]ver[00]1.0.1[00]h-beat[00]60[00]buff-in[00]256[00]dev[00]Arduino Uno[00]cpu[00]ATmega328P[00]con[00]SIM800[00]fw-type[00]TMPLV2vFKdqU[00]build[00]Feb 21 2022 13:55:16[00]tmpl[00]TMPLV2vFKdqU[00]
13:56:06.581 → [36269] Cmd error
Please see my code below
#define BLYNK_TEMPLATE_ID "TMPLV2vFKdqU"
#define BLYNK_DEVICE_NAME "Dev1"
#define BLYNK_AUTH_TOKEN "JKKBMrNTb6SM12jWdBtilx6gEFzhASCd"
#define BLYNK_DEBUG
#include "DFRobot_INA219.h"
char apn[] = "Justworx";
char user[] = "";
char pass[] = "";
#include <DHT.h>
#define DHT11_PIN 7
#define DHTTYPE DHT22
DFRobot_INA219_IIC ina219(&Wire, INA219_I2C_ADDRESS4);
float busvoltage = 0;
float ina219Reading_mA = 1000;
float extMeterReading_mA = 1000;
void SendDhtData()
float Voltage = ina219.getBusVoltage_V();
return;
Serial.println(t);
Serial.println(h);
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V2,Voltage);
* setup() function
delay(3000);
dht.begin();
//modem.restart();
Serial.println();
while (ina219.begin() != true) {
Serial.println("INA219 begin faild");
delay(2000);
ina219.linearCalibrate(ina219Reading_mA, extMeterReading_mA);
Serial.println();
* loop() function
