is there any chance to have 2 TABS menu in the same screen?
1st TAB will command main function (like REMOTE)
2nd TAB will command the right remote showing just the appropriate buttons.
@Costas → device selector seems more related to hardware side. @eugene–> unfortunatly I’m already using a TAB menu in my project.
It seems that I can have more thank 1 tab/project (maybe is a bug).
a solution could be:
1st design a button with that push a string like this:
// Send string
Blynk.virtualWrite(pin, “abc”);
this string will contain different remote names
2nd set up the full keyboard just one time…
3rd create if condition with “and” and maybe use adjustiment on button colors.
with this set up if a button isn’t usable in the specific configuration will be grey.
You only need one Tab Widget per project, just add more tabs to it as you need (up to max of four). Each tab then has it’s own screen that you can place widgets on.
As he said, a bit messy, but here are some examples I use to black out and “deactivate” a button/switch.
// Call this when wishing to "activate" button.
void buttonActivate() {
ButtonFlag = 1; // Set button active flag HIGH.
Blynk.setProperty(V1, "color", "#0000FF"); // Set button to BLUE.
// Call this when wishing to "deactivate" button.
void buttonDeactivate() {
ButtonFlag = 0; // Set button active flag LOW.
Blynk.setProperty(V1, "color", "#000000"); // Set button to BLACK.
// Call this when button pushed.
BLYNK_WRITE(V1) {
if (ButtonFlag == 1) { // Only do stuff if button active.
Blynk.setProperty(V1, "color", "#00FF00"); // Set button to GREEN.
// Do Stuff here.
Blynk.setProperty(V1, "color", "#0000FF"); // Set button back to BLUE.
